Author Topic: Kawasaki Brake Caliper Pistons  (Read 1664 times)
Offline colin400four
« on: June 17, 2011, 07:20:49 PM »
Hi folks,
I recently bought a spare set of calipers from the internet with a view to restoring them to give me a spare set should problems arise with the originals on the bike. The calipers are for a 2008 kawasaki Z750.
I stripped down the calipers then got to work cleaning the grime / rust from the caliper pistons.
pics 1, 3 & 4  show the before and after of the cleaning. I used grade 400 wet & dry paper with solvol autosol to remove the worst of the grime, then I buffed the pistons with the polishing wheel ......... the wheel is made of tough string,  so no metal content.
I was quite pleased with the results but as you can see there remains some pitting at the top of the piston.
Bearing in mind that these puppies cost
