Author Topic: front mudguard mounting 550f2  (Read 2039 times)
Offline kendo57
« on: June 26, 2011, 09:06:20 PM »
Can someone tell me if the left mudguard mount fits behined the brake swivel bracket
or bolts to the top of it.
Looking at pictures in my old manual [cb500] it looks to bolt between the forkleg and
brake bracket but i am sure on mine it was bolted to the outside of the bracket.
Offline florence
Re: front mudguard mounting 550f2
« Reply #1 on: June 27, 2011, 09:08:49 AM »
It should be behind, i.e, next to the fork leg, then bracket on top of it.
Offline kendo57
« Reply #2 on: June 27, 2011, 11:07:43 AM »
Thanks, it looks like the previous owner has bent the bracket and fitted to the outside.
« Reply #3 on: June 27, 2011, 02:35:11 PM »
I've just checked on mine and Steve (Florence) is correct.
If yours is the other way round the movement of the front brake caliper must be compromised (?)
2022 Tiger Sport 660
Offline florence
« Reply #4 on: June 28, 2011, 11:09:52 AM »
Oh my golly gosh, I've just looked at mine and you are correct.  The mudguard is on the outside.  Humble apologies :-[
Offline kendo57
« Reply #5 on: June 28, 2011, 10:43:38 PM »
Well the way the bracket is  shaped it looks like it should go on the outside and
i have found a picture in the CB500 manual showing it on the outside.
So i think Oddjob has now convinced me the outside is the way to go.
Thanks again.
