Author Topic: Just a tip  (Read 1211 times)
Offline Paull
Just a tip
« on: August 01, 2011, 05:22:56 PM »
Hi All,
I have just found out you can use the long 12mm fine tread engine mounting bolt (thats the bottom one)to pull the primary shaft out the case before you split it, no need for special tools.
I don't know if this will help anyone or if someone else has done it.
There you go
Paul
S**t Happens
