Author Topic: Oil filter cover bolt seized  (Read 6123 times)
Offline Tomb
Re: Oil filter cover bolt seized
« Reply #15 on: November 25, 2011, 09:51:31 AM »
Beautiful repair Bill
It might be wise to give it another coat of paint after fitting it, tightening will chip the paint.
Its for that reason (like PatM) I welded a stainless nut over the chewed up remains of mine.
Tom
'62 CB77 Sprinter
'70 CD175
'78 CB550 with sidecar
'80 Z50R
« Reply #16 on: November 25, 2011, 06:20:28 PM »
That's a very nice repair job and a part well restored.
People often do these up so tight as if their life depended on it when all it needs is to only just compress the O-ring and no more, you can feel it when the filter housing just starts to touch the cases and stop there.
Offline meerkat
« Reply #17 on: November 25, 2011, 08:38:22 PM »
Thanks Tomb and K2-K6 for your kind comments.
The sump drain plug was also repaired the same way and both have now been re-fitted. The bike's been filled with fresh oil and the engine turned over without firing to avoid getting petrol down the dry bores.
Just waiting for a break in the weather to go for a run in a much easier frame of mind than this time last week.  ;D
Here's another picture of the bike.
Retired and spending my children's inheritance.
