Author Topic: Speedo/tacho needle removal  (Read 1710 times)
Offline Oldbuthopeful
« on: December 30, 2011, 11:19:49 AM »
I'm in the process of applying new vinyl overlays to speedo and tacho faces on my 350F1 and have taken off one of the bezels, using a Dremel type drill.  As if that wasn't daunting enough (had to bear in mind that they were going to go back on and not look as though they'd been attacked with a cold chisel)  -  I'm now stumped with the problem of getting the needle off.
Anyone any useful hints please?
Offline ST1100
Re: Speedo/tacho needle removal
« Reply #1 on: December 30, 2011, 12:01:04 PM »
Saw a method using a small desert fork to pry it off somewhere in the Inet.
STOC #637
Offline steff750
  • THE POWER OF DREAMS
« Reply #2 on: December 30, 2011, 02:07:33 PM »
Quote
pry it off
                  yes if they are the same as the CB750 you can pop them straight off
« Reply #3 on: December 30, 2011, 05:39:45 PM »
Many thanks for both replies.  I'll report back after the next phase of surgery. Might even manage some before and after pics.
Offline kent400
« Reply #4 on: December 30, 2011, 06:18:09 PM »
Two tea spoons under the needle boss and resting on the dial face securing screws. Equal pressure on both sides to ensure the needle spindle isn't bent. Not sure about attacking the band with a Dremel, an email address would bring you a restoration guide in PDF for these instruments.
