Author Topic: Which brakes? ...and headlight brackets  (Read 3675 times)
Offline kifer
Re: Which brakes? ...and headlight brackets
« Reply #15 on: March 09, 2012, 02:56:25 PM »
Hi Robbo an easy way to bleed brakes is to use a syringe [ DIRT CHEAP LAST FOREVER ] You can then pull the fluid through also no jar no mess easy and quick. Good luck ;D
Offline Robbo
« Reply #16 on: March 09, 2012, 04:11:14 PM »
Noted! Do you put it in the end of the tube attached to the bleed nipple and do you have to have the level slightly pulled or can you just suck it all through?
Offline kifer
« Reply #17 on: March 09, 2012, 05:21:34 PM »
I got syringe off mechanic mate, its about 30mm dia and 150mm long I just top up master cylinder then draw it through bleed nipple, Its clear so you can see the air Takes minutes, can't see your problem with carbs are float bowls set and taking fuel to correct level seems very strange all 4 carbs, would understand 1 maybe 2 but not all 4 of the bar stewards ?   :'(
Offline Yoshi823
  • Biker to the bone...
« Reply #18 on: March 09, 2012, 11:20:52 PM »
A few years ago I fitted CB900FC twin piston calipers to my CB750F2 & they bolted straight on with no mods required at all
Bikes...they're in the blood.
Yamaha R1 2001
Yamaha FZR1000R EXUP 1990
KTM 450 EXC RFS 2004
Honda XR400R 1997
Honda CB125T2 1980
Yamaha FJ1200 3XW 1991
Offline Robbo
« Reply #19 on: March 10, 2012, 09:59:02 AM »
A friend offered me his CB900 callipers but they didn't seem to fit - I might have another look then? Picking up the new calliper pistons today so I'll let you know how I go.
I think I might not have the correct master cylinder - Mine has a rectangular reservoir not a round one...
