Author Topic: Fastner Locking  (Read 1681 times)
701arvn
Fastner Locking
« on: February 26, 2012, 11:12:24 AM »
Not wishing to bore the more knowledgeable amongst you, but I stumbled on this thread and found it very interesting:
http://www.triumphrat.net/maintenance-and-workshop-talk/167681-do-you-loctite-everything.html
take a look at post number 4.
Andy.
Offline LesterPiglet
  • 1977 CB550F2
Re: Fastner Locking
« Reply #1 on: February 26, 2012, 06:37:00 PM »
Good to know.
Offline matthewmosse
Re: Fastner Locking
« Reply #2 on: February 26, 2012, 09:02:05 PM »
If lock washers are as u/s as some posters imply, they'd better take a look at the various fastners I've undone, a lot where the ut actually had a raised lump of metal where the spring washer had gouged the nut when removing it. I rarely use threadlocking compound but do often use spring washers and copper slip and stuff genrally stays done up until I get a spanner and remove it, in fact I can think of very few if any bolts on my bikes that have fallen out or come undone in 10 years of riding all year round. Natrually if nylocks were specified originally I use them but I must admit to reuing them if in good condition, if the nylock insert is worn then that is when the tread locker compound comes out, and where its specified for jobs like brakes.
Online Bryanj
Re: Fastner Locking
« Reply #3 on: February 27, 2012, 06:43:04 AM »
Can't be arsed with threadlocker, just use a couple of turns of PTFE tape
701arvn
Re: Fastner Locking
« Reply #4 on: February 27, 2012, 08:43:59 PM »
Mathewmosse
sadly I found the discussion on the thread quite fascinating; I think's it's further down somebody makes the distinction between locking and impeding the loosening of the nut.
Basically, that the spring washer may slow the nut coming off (via the groove you mention); but it doesn't lock it.
This may be one of those fine distinctions significant only if you are building space rockets and jet fighters and not if putting old motorbikes together.
Personally, I've always sworn by the spring washer, as I can't be bothered with loctite either but I am now having my doubts.
