Author Topic: Front brake Resevoir problem? Bleeding Brakes!!!!!  (Read 5381 times)
Offline ST1100
Re: Front brake Resevoir problem? Bleeding Brakes!!!!!
« Reply #15 on: September 08, 2012, 12:03:00 PM »
Is this because the air bubbles gradually float up to the top?
Might have accelerated this by placing a rubber band or a zip-tie over brake lever & grip and leave it over night.
Best however is having a compressor avail and use an air powered brake bleeder, as this provides sufficient flow rates for proper bleeding.
(as example: http://www.ebay.de/itm/ws/eBayISAPI.dll?ViewItem=&clk_rvr_id=384670726833&item=261093392693&meta_categ_id=99423&ebayCategoryId=99423)
STOC #637
Offline madoc
« Reply #16 on: September 11, 2012, 03:40:20 PM »
Blimey.
I just did the same; changed to braided cable and it refused to bleed well with my handy "brake bleeding kit".
I left it overnight with the lever tied back to the grip (you can do the same with cars by chocking the brake pedal down) which is my usual patent safe method. That didn't work but I had a wedding Saturday.
I came back to it on day three (Sunday) and the "lever tied back" method still hadn't worked BUT it then bled correctly at that point.
Dunno.
I assume lots of air in the system that just needed to work their way out.
Lever is not actually any firmer than before BUT I cannot now feel the upper hose expanding.
Road test next (with the new rings, camchain etc) - will it go and stop better ....
« Last Edit: September 11, 2012, 04:02:47 PM by madoc »
Offline Yoshi823
  • Biker to the bone...
« Reply #17 on: September 14, 2012, 03:37:28 PM »
When I installed a twin disc setup on my CB550F2 I used CB250N Superdream bleed nipples which are 10mm af & are much easier to use when bleeding the brakes
Bikes...they're in the blood.
Yamaha R1 2001
Yamaha FZR1000R EXUP 1990
KTM 450 EXC RFS 2004
Honda XR400R 1997
Honda CB125T2 1980
Yamaha FJ1200 3XW 1991
