Author Topic: 750 misfire / running on 2  (Read 1749 times)
Offline Waggles
« on: June 26, 2012, 07:36:50 AM »
If this is your problem check the connectors where the points wires connect to the loom, its by the rear brake light switch inside a plastic 'boot'. The wires have no spare length and the connectors can be strained and disconnect / come loose.
Consider wiring them together or replacing with longer ones / splicing in a bit of extra length
