Author Topic: 400/4 Tacho drive  (Read 1384 times)
Offline Beemer634
400/4 Tacho drive
« on: June 29, 2012, 09:45:55 PM »
My refurb of the 400 is going relatively problem free, just finishing the engine build and I have just found a most annoying problem that I can't seem to fathom out, I am hoping it is not an act of total muppetry on my part!!!
On attempting to replace the tacho drive gear into the rocker cover I dont seem to be able to get the guide sleeve far enough into its hole to permit the oil seal to be fitted correctly. I have checked the hole - No obstructions. It came out when I stripped it all down and it dawned on me...should I have fitted the drive from the inside of the rocker cover prior to refitting?  !!!
I am embarrassed having to put this in the public domain!!!
Wincing...Expecting a barrage of flak!
Rick
'77 BMW R100RS
'77 400/4
'76 750/4
'72 500/4
Re: 400/4 Tacho drive
« Reply #1 on: June 30, 2012, 09:23:07 AM »
Yes, you should have fitted the oil seal first, then fitted the drive gear from INSIDE the cover ??? Not a major problem though, just fiddly putting the cover back on when you have fitted it properly :D
Offline Beemer634
« Reply #2 on: June 30, 2012, 09:36:23 AM »
DOH!!
Oh well, at least I can stay out of the rain for a while longer!
I appreciate the swift reply.
Rick
'77 BMW R100RS
'77 400/4
'76 750/4
'72 500/4
