Author Topic: Tapered Drain/Sump bolts  (Read 1820 times)
Online andy120t
« on: August 20, 2012, 09:15:22 PM »
Flicking through Practical Classics Car mag today & found mention in the letters page of tapered drain plugs as a way of solving stripped threads. It didn't give much detail - so a quick look online tells me that these are a form of self-tapping plug / thread slightly larger than the standard and are used to recut a thread when the original has been stripped.
So -anyone heard of these? Used them?....used them on a motorbike...such as a CB650...
..as the pool of oil on the shed floor and my sump plug giving little resistance seems to indicate that I have a problem!
Re: Tapered Drain/Sump bolts
« Reply #1 on: August 20, 2012, 09:29:57 PM »
Seen one used a few years ago, it just cracked the sump pan forcing the owner to find a good replacement :'( Far safer to remove the sump and repair it properly with a helicoil or timesert, not expensive even if you can't do it yourself ;D
Offline matthewmosse
« Reply #2 on: August 21, 2012, 04:39:32 PM »
I have found helicoils often wind themselfs back out when undoing fastners which can be annoying and costly on things you undo reguarly like sump plugs - I've yet to try timserts which I'm told are better in that regard. I think sumps are same on 500 and 550, if that is the case I have a few spares with good threads in the sump plugs.
Offline ST1100
« Reply #3 on: August 21, 2012, 07:21:48 PM »
TimeSert are excellent, if there is sufficient 'meat' around the bore... like engine mounts and such.
STOC #637
Online andy120t
« Reply #4 on: September 01, 2012, 07:31:15 PM »
Cheers Matt - I think I'll try a helicoil as it'll be the first time so may as well have a go - might take you up on the sump after that!
Any idea what size helicoil kit I need for it? (bike currently buried in the shed & I can't reach the bolt without shifting stuff..)
