Author Topic: Steering stem bearings ??  (Read 1665 times)
Offline cb750stu
« on: September 04, 2012, 07:23:36 PM »
Hi Folks
Just wondering how to get these rings off they are solid if i put it in the freezer will that work ??
I looks like there are 4 parts there ,
Does all that assembly come off or just the top 2 rings ???
1976 CB750 F1 SS in bits !!! but getting there
Offline LesterPiglet
  • 1977 CB550F2
Re: Steering stem bearings ??
« Reply #1 on: September 04, 2012, 07:38:56 PM »
The very top is a spacer. It all comes off up to the spacer, unless the spacer is the wrong size then that comes off too. I just used a bfh and an old screwdriver. Just work your way around the bearings a bit at a time and it should come off.
Offline cb750stu
« Reply #2 on: September 04, 2012, 07:50:10 PM »
Cheers !!!
As you can see in the top picture i have tried the BFH route i think i will go and hit it a bit harder !!!
Offline the-chauffeur
« Reply #3 on: September 04, 2012, 09:03:02 PM »
Stu
I've always found the lower races a bloody nightmare to remove.  I've finally settled on a somewhat unconventional - but effective - solution.  I use a small axe head (like a wide bladed cold chisel) against the bottom race edge and strike the back of it with a heavy hammer.  Since both tools are hardened, I wear goggles and gloves, just in case.
The other thing I do is brace the top end against a piece of wood up against a wall.  With the whack I need to give these things, I find that vices just don't cope.
Alternatively there's always the elegant solution of using a Dremel to cut through 2/3rds-3/4trs of the race width and then snap the remainder with your hammer/cold chisel . . .
Offline cb750stu
« Reply #4 on: September 04, 2012, 09:22:21 PM »
Yeah ive just finished with my Dremmel worked a treat !!
I just test fitted my new bearings,i take it when i put it back together they will move down when tightening up because at the moment they dont go all the way down to the bottom they seem a bit snug ??
Cheers for the advice
  • 1977 CB550F2
« Reply #5 on: September 04, 2012, 11:34:18 PM »
I just fitted tapers a few months ago and I'm still trying to set them right. Either too tight or too loose.  ::)
« Reply #6 on: September 05, 2012, 04:15:55 PM »
The bearings need to go all the way to the bottom of the steering stem - and yes, that's a bastard of a job if you don't happen to have exactly the right diameter piece of pipe knocking about to belt them on with.  Or even better, a hydraulic press.
I've just done the same job on my Pan European.  The interference fit between the stem and the lower race is incredibly tight - I used a variety of tools to get them down, but the most useful thing was the old bearing race lower half, which I could put over the new one to protect it when I was bearing (ha - see what I did there?) down on the whole assembly.
And don't forget, the seal with the rubber edges goes on first, then the bearing . . . been there, done that.
« Last Edit: September 06, 2012, 10:59:25 AM by the-chauffeur »
