Author Topic: Timing  (Read 1623 times)
Offline Robbo
Timing
« on: September 19, 2012, 10:05:34 AM »
Have really enjoyed riding my naked PRR around in the sunshine, although when I set the timing with a strobe 1-4 were perfect but 2-3 bounced all over the place. Points and condenser are both quite new. Not sure what else could cause it, although 2-3 coil is a new aftermarket one which is a little smaller than the original, could this be the problem?
It pops when cold, usually on tickover or deceleration, I put that down to my unbaffled motad 4-1, I have overwelded any holes in the pipes though and when I use my hand or wire will as a temp baffle it still pops.
Shall I try new points/condenser? Is the coil the culprit - how do I tell?
Re: Timing
« Reply #1 on: September 19, 2012, 02:20:34 PM »
Throw away the strobe abd time it static as per the Manual, never used a strobe in all the years at dealers---only to check the advancer was working!
Offline Robbo
Re: Timing
« Reply #2 on: September 19, 2012, 02:47:51 PM »
Still popping when static timed
Re: Timing
« Reply #3 on: September 20, 2012, 07:17:54 AM »
Most likely an air leak
Offline Robbo
Re: Timing
« Reply #4 on: September 20, 2012, 12:01:29 PM »
No change when I spray wd40 on the inlet rubbers, any other way I can tell if there is a leak?
Offline ST1100
Re: Timing
« Reply #5 on: September 20, 2012, 04:36:57 PM »
Use ether (starting aid spray from your lawn mower) or brake cleaner instead...
I doubt that WD-40 is sufficiently combustible...
STOC #637
