Author Topic: Carb Rebuilders ??  (Read 1937 times)
Offline cb750stu
Carb Rebuilders ??
« on: September 19, 2012, 08:59:17 PM »
Hi Folks i am wanting to get my carbs Ultrasonic cleaning stripped and rebuilt with all new kit inside and out can anyone recommened me anyone who does this ??
Regards
Stu
1976 CB750 F1 SS in bits !!! but getting there
Offline archmill
Re: Carb Rebuilders ??
« Reply #1 on: September 19, 2012, 11:34:27 PM »
Did mine with a 20 quid ultrasonic cleaner from Aldi's and US Carbclean bought off E-bay. Then laid into them with a toothbrush and Solvol Autosol. Shinier than a shiny thing.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #2 on: September 20, 2012, 01:38:54 AM »
What size is that cleaner Arch?
Offline cb750stu
« Reply #3 on: September 20, 2012, 11:39:05 AM »
Did u totally strip the carbs to get them that shiny ??
Carbs are not my strong point so I would rather get them done professionally
They look amazing though
Regards
Offline archmill
« Reply #4 on: September 20, 2012, 11:16:00 PM »
Lesterpiglet, here's a link to the same one I used:- http://www.ebay.co.uk/itm/DIGITAL-HIGH-FREQUENCY-ULTRASONIC-CLEANER-JEWELLERY-DVDS-MATALWARE-ETC-WOW-/160886040559?pt=UK_Jewellery_Watches_JewelleryBoxes_Supplies_CA&hash=item25758e27ef#ht_500wt_1203
CB750stu, yes you do have to strip the carbs completely. It's no big deal really, all you need is a good quality philips screwdriver and a couple of sockets. Best to take loads of photo's to see how to re-build them and do one carb at a time so as not to mix up all the parts. The down side of the ultrasonic cleaner is 1) it only runs for about 4 minutes so you have to be there to keep turning it on and 2) the main carb bodies won't fully submerge in such a small tank so you have to do one half then turn it over to do the other side. I found that the carb parts were all fully servicable except for a couple of O rings and they were in a shed for 30 years.
  • 1977 CB550F2
« Reply #5 on: September 21, 2012, 12:23:16 AM »
Is that around 600ml then?
Offline archmill
« Reply #6 on: September 21, 2012, 05:57:57 PM »
550ml on the box.
  • 1977 CB550F2
« Reply #7 on: September 21, 2012, 11:19:49 PM »
Thanks.  ;)
