Author Topic: Kickstart ratchet??  (Read 1143 times)
Offline Jimbo550
Kickstart ratchet??
« on: November 07, 2012, 12:53:27 PM »
Hi. I've just but the bottom end crank cases back together all bolted up, selector shaft is in and now trying that all gears select correctly before I carry on. As I turn the main shaft by hand in the correct direction I hear the kickstart ratchet. In the other direction the main shaft is locked.  What have I done wrong?
Offline Jimbo550
Re: Kickstart ratchet??
« Reply #1 on: November 07, 2012, 02:31:45 PM »
Don't panic i,ve sorted the problem.  Got the kick start ratchet 180 deg out.  Thankfully i could dismantle and reasemble from the bottom without splitting the cases.
« Reply #2 on: November 07, 2012, 03:05:53 PM »
Before you go any further make sure that the leg on the mechanism is in the slot in the crankcase where it is supposed to go!!!
Offline Jimbo550
« Reply #3 on: November 07, 2012, 09:11:03 PM »
The leg is in the slot.  I just had the ratchet 180 degrees out.  all working fine now.
