Author Topic: rear brake arm / spring  (Read 1415 times)
Offline buxtonmick
  • I must be mad
« on: November 12, 2012, 09:10:34 AM »
Can someone inform me as to the correct fitting of the rear brake arm & spring assembly please?  I've got it all in but the spring for the brake light switch is far too loose and of course will not hold the switch in its bracket.  I've probably got the spring wrapped behind the wrong bit of frame or something...
Cheers, Mick.
Offline tom400f
Re: rear brake arm / spring
« Reply #1 on: November 12, 2012, 11:04:10 AM »
Like you I took it apart without photographing, thinking nah I can remember how that goes back....
This works so I assume its right. The last picture shows the view from the other side, with the hook of the spring coming round under the arm that operates the switch.
« Last Edit: November 12, 2012, 08:44:49 PM by tom400f »
1978 CB400F2 Yellow
1995 VFR750FS Red
1997 VFR750FV Lapis Blue
2013 Yamaha FZ8 Grey
Offline buxtonmick
  • I must be mad
« Reply #2 on: November 12, 2012, 10:50:47 PM »
Brilliant Tom, thanks a lot!  Spring is on fine - I've got the arm upside down for some reason, which means the pedal would have to be pulled up to apply the brake... :-[
Cheers, Mick.
