Author Topic: A few wheel questions???  (Read 1040 times)
Offline cb750stu
« on: November 23, 2012, 07:48:26 PM »
Hi Folks i just got my wheels back from Central Wheels today what you all think ive gone for something different to match my Honda colour scheme!!!
What is the best way to press in the bearings heat/cold ??
Does the distance collar have a specific way it goes in it is slightly different at each end ???
http://www.cmsnl.com/honda-cb750f1-super-sport-1976-england_model14680/collar-distance_42620392000/
Anyway thanks
Regards
Stuart
1976 CB750 F1 SS in bits !!! but getting there
Offline Seamus
Re: A few wheel questions???
« Reply #1 on: November 26, 2012, 10:29:38 AM »
Wheels look good. Obviously not standard colours, but on the right machine, they would look really cool.
Ususlly cool bearings down in the freezer prior to fitting as it helps a bit. You can tap the bearings in using a suitable sized socket, or press if you have one. Another option is a threaded bar with heavy washers on either side to pull the bearing in.
I assume you are working from a manual as I believe that the rhs one has to be fitted first. (need to check that though). When fitting the second bearing, it only needs to nip up on the central spacer to hold it in place.
Offline cb750stu
« Reply #2 on: November 27, 2012, 08:58:40 AM »
Cheers Seamus for the comments i thought i would go for something different(not everyones cup of tea) to match the colour scheme i am going for,
Regards
Stuart
Offline UK Pete
« Reply #3 on: November 27, 2012, 11:33:13 AM »
I agree those wheels look the business, they will make the bike look awsome
Pete
