Author Topic: Rubber rejuvination.  (Read 1953 times)
Offline Captain Snakebite
« on: January 15, 2013, 11:17:45 PM »
Don't worry, it's nothing to do with geriatric fetishists on viagra - I've just had a try of the How To Refurb Rubber thing from this month's Practical Sportsbike and it's worked!
For anyone who's read the article and thought "Hmm..." I'd say give it a go. Two CB550 carb-to-manifold rubbers are now eminently flexible enough to use again - and they were stiffer than the aforementioned geriatrics before receiving the treatment.
The only thing I did differently to the article was to pop the rubbers in a container inside the pan of water - a double boiler affair - and cover 'em with the 50:1 solution recommended in the article. This has two benefits over a plain pan - firstly, you use less of the water / Wintergreen mixture and secondly it helps control the temperature better.
Popped them in and left to cook away for 90 mins with an occasional jiggle to keep things nice and even, I've just fished 'em out and given a good wash in cold water and Bob's my Uncle!
Okay, so at a tenner for the Wintergreen oil it's not that much cheaper than new bits from DSS, but it's handy to know it'll work for the more expensive or hard-to-come-by rubbery bits. ;D
If it ain't broke - it'll probably wait 'til it's raining and you've got to be somewhere important.
Offline Rozabikes Tim
Re: Rubber rejuvination.
« Reply #1 on: January 16, 2013, 07:58:49 AM »
Good to see first hand experience of these things. I did read the article and it seemed like alchemy. Or in the words of blackadder - I've invented green Edmund!
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #2 on: January 24, 2013, 05:26:30 PM »
I've just tried this trick with a coupe of instrument lighting rubber bayonettes (CB750 K2 type) - and had to write 'em off. The 'bayonette' walls swelled to a somewhat larger diameter, tho' did become very rubbery! Suspect the process has to be tailored to the size of part you're dealing with.
Notably the 40yr old loom wire insulation - fairly stiff with age - softened up amazingly, swelling to perhaps twice previous diameter. Very rubbery again, with strength maintained. On the flip side it just didn't feel right, more akin to the rubber coated cables pre the modern insulation materials.
