Author Topic: Cb750 K2 / HM341 baffles  (Read 1948 times)
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« on: January 24, 2013, 05:29:24 PM »
.... won't be playing with the bike for a couple of months and simply wanted to squirt WD40 down the 'pipes for laying up. Removed the single 10mm bolt from each pipe... but the baffles showing no signs of wanting to let go. Any tips / tricks? What's the best 'bit' to pull on?!
Thanks...
Offline Green1
Re: Cb750 K2 / HM341 baffles
« Reply #1 on: January 24, 2013, 08:39:13 PM »
Hi lobo
You don't get removable baffles in the hm341's  only in the hm300's
Loads of WD40 and a large flat head screwdriver on the back edge of the diffuser and a gentle tap will get them out and then you will see the baffles inside
Mick
« Last Edit: January 24, 2013, 09:06:49 PM by Green1 »
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Honda CG125
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #2 on: January 24, 2013, 09:27:44 PM »
Cheers Mick,
Still a bit confused....do I take it that the 'diffuser' is the only removable bit on the '341's?  And if the baffes are non-removable am I wasting my time trying to get a clear passage down the pipe to take a squirt of WD40?
Many thanks...
Offline Green1
« Reply #3 on: January 24, 2013, 09:35:40 PM »
The diffuser is the only removable bit.I still squirt WD40 down my pipes and wrap a bit of plastic around the end of the pipes to keep the damp out as my bikes share the garage with the tumble dryer  :(
Current bikes
Honda CG125
Aprilia Pegaso 650
Kawasaki ZXR400 J
