Author Topic: Points wiring  (Read 1412 times)
Offline Seamus
Points wiring
« on: February 19, 2013, 04:47:10 PM »
Just a quickie, but is the small harness that goes to the points fixed to the sump or along the bottom of the clutch cover?
Offline steven400/4
Re: Points wiring
« Reply #1 on: February 19, 2013, 05:25:00 PM »
goes between point cover and clutch case then up over the top of clutch cover
cb400f2 x7
honda ss 50
gsx 1400
Offline Seamus
Re: Points wiring
« Reply #2 on: February 19, 2013, 06:57:01 PM »
Thanks for the reply.
So the mounting tabs are bolted through the top engine case bolts?
Offline steven400/4
Re: Points wiring
« Reply #3 on: February 19, 2013, 07:04:01 PM »
yes one inbetween casing and cover and one of the top bolts of engine under the carbs
cb400f2 x7
honda ss 50
gsx 1400
Offline Seamus
Re: Points wiring
« Reply #4 on: February 19, 2013, 10:29:59 PM »
Thanks Steven
