Author Topic: brake master cylinder circlip removal  (Read 1946 times)
59viperman
« on: April 04, 2013, 10:00:36 PM »
 >:( can someone please tell me how to remove the circlip from the front brake master cylinder, I have bought a rebuild kit because mine is leaking [ like the petrol tank] . I have removed the ring below the rubber boot but I cant shift the circlip. I am using circlip pliers but its a three handed job trying to keep the piston down while I get at it. any tips before I throw it in the bin and buy a new one ?
Re: brake master cylinder circlip removal
« Reply #1 on: April 05, 2013, 07:31:32 AM »
Reseverence and the correct bent pliers mate. I always use a plumbers type blowtorch to warm up down the hole and remove rust then if you push the piston in as far as possible a lot of the time it sticks down
Offline tom400f
1978 CB400F2 Yellow
1995 VFR750FS Red
1997 VFR750FV Lapis Blue
2013 Yamaha FZ8 Grey
59viperman
« Reply #3 on: April 05, 2013, 01:07:02 PM »
 ;D thanks chaps will try everything,
59viperman
« Reply #4 on: April 05, 2013, 07:51:05 PM »
 ;D eureka, job done. ha ha  8)
