Author Topic: damaged cooling fins  (Read 2314 times)
Offline ianmck
« on: April 13, 2013, 08:29:11 PM »
can anyone give me some advice, I have a couple of damaged cooling fins on the engine, any ideas on repairing them, the engine is out but I dont want to strip it if poss.
1977 400/4 supersport.   1973 cb750 K4,
Offline Bob Wessner
Re: damaged cooling fins
« Reply #1 on: April 13, 2013, 08:49:02 PM »
I used an epoxy clay to replace a chunk out of the very top fin on my 750. That was about 6 years ago and it's still there, no problems.
Offline Bob Wessner
« Reply #2 on: April 13, 2013, 10:03:35 PM »
Finally found the thread where this was discussed (U.S. Forum) and the product I used. Hope it is of some help.
http://forums.sohc4.net/index.php?topic=19402.msg202306#msg202306
Offline ianmck
« Reply #3 on: April 14, 2013, 08:21:45 PM »
Bob you are a star, thank you for your efforts, I will try to find the same or something simmilar over here. thanks again, Ian.
« Reply #4 on: April 15, 2013, 06:29:58 AM »
Devcon, if its still made, used to do a metallic based epoxy putty for all the different metals
Offline Bob Wessner
« Reply #5 on: April 15, 2013, 11:24:27 AM »
Wasn't aware of this one. It appears Devcon is still available but at this site it's pricey and the quantity is a bit much.  :-\
http://www.ellsworth.com/devcon-aluminum-putty-f-1lb-kit/
« Reply #6 on: April 15, 2013, 05:08:35 PM »
Used the steel, brass and alloy types when in the merchant navy Bob. When used correctly it will take a thread as long as you dont want extreme torque. Also used some etuff called Thistlebond that i havent seen for a while----was a woven glassfibre bandage along with a resin and hardener, didn't half get hot quick and burnt fingers!!!
Offline Bob Wessner
« Reply #7 on: April 15, 2013, 06:53:17 PM »
Bryanj, looks like Thistlebond is still around also.
http://www.thistlebond.info/products/engineering/metalrepair.htm
Where were you with all this knowledge six years ago when I needed it?  ;D
« Reply #8 on: April 16, 2013, 08:36:03 AM »
Sorry Bob, was building No 36 for the first time i think!
The Thistlebond I remember was
http://www.thistlebond.info/products/addedinfo/TRK2006.htm
Never knew of the other stuff, it was the Devcon for that.
All the best mate
