Author Topic: HT lead jointer supplier  (Read 1555 times)
Offline stuartni
« on: September 17, 2013, 03:23:50 PM »
Can anyone point my in the direction of 7mm ht lead joint/s supplier not having any luck.thanks
Offline matthewmosse
Re: HT lead jointer supplier
« Reply #1 on: September 17, 2013, 04:35:02 PM »
Vehicle wiring products had  them in their last catalouge I had a look at.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #2 on: September 17, 2013, 05:03:58 PM »
Any use Stuart? Failing this a 'double-ended' screw insert joining your cables, with heat shrink cable as sheath? (assuming you're using copper cored HT leads versus the carbon type)
http://www.autoelectricsupplies.co.uk/product/682
« Last Edit: September 17, 2013, 05:06:17 PM by Lobo »
« Reply #3 on: September 18, 2013, 07:20:43 AM »
NGK make them
http://www.ngksparkplugs.com/docs/Resistor_Covers.pdf
scroll to bottom and ask at your local emporium
Offline stuartni
« Reply #4 on: September 18, 2013, 08:51:32 AM »
Excellent guys quite like the look of the NGK one only thing is NGK uk dont stock them so will have or from america  8)
Offline LesterPiglet
  • 1977 CB550F2
« Reply #5 on: December 07, 2013, 09:42:35 PM »
I could have done that for you Stu.  ::)
