Author Topic: Ive been busy today !!!  (Read 1550 times)
Offline cb750stu
« on: September 21, 2013, 09:58:53 PM »
Hi Folks just thought i would post some pics of my build progress !!
The frame went in no problem using the lower the frame down over with the engine on its side method !!!
Swingarm wasnt easy its a tight fit my 5 year old son helped me !!!
Carbs went on quite easily with the help of a smear of Fairy liquid  and new carb rubbers!!!
I know it looks like thers not much room between the top of wheel and frame but its resessed underneath i have 4.5 " to play with and the suspension is pretty stiff lol
Couple of questions if you dont mind ??
Am i best to fit the front calipers before the wheel or vice versa ??
When i tried to fit the front wheel there is still play from side to side does the hex part of the spindle nut go to the outside or inside ??
Anyway ill keep posting pics of my build !!
Cheers    Stuart
« Last Edit: September 21, 2013, 10:05:03 PM by cb750stu »
1976 CB750 F1 SS in bits !!! but getting there
Offline Ewan 500 K1
  • jings crivens help ma boab
    • Adams Bros Probe 2001
Re: Ive been busy today !!!
« Reply #1 on: September 21, 2013, 10:10:41 PM »
... 4.5" with the bike in the air ? ... or on the ground ?
Will the tyre fit in between the two calipers is the key I suppose ?
When i tried to fit the front wheel there is still play from side to side does the hex part of the spindle nut go to the outside or inside ??[/b]
hex to the inside on the 500 four, think its the same on the 750. You could check the parts schematic at http://www.motogrid.com/p/OEM-Parts#/Honda/CB750K5_A__MOTORCYCLE%2c_JPN%2c_VIN%23_CB750-2500001/FRONT_WHEEL/CB750K5-JPN-A/2Y143413F14341307B
500K1 basket case for later
Offline Ewan 500 K1
« Reply #2 on: September 21, 2013, 10:12:52 PM »
I've been dithering on whether to go black or silver on my frame .... like silver , but dont want to have to claen it all the time .... but going white .. !!!! .  You've convinced me .. I'm going silver  ;D ;D
Offline cb750stu
« Reply #3 on: September 21, 2013, 10:38:21 PM »
Cheers Ewan for the info !!!
Yeah it goes down to around 3 " when on the ground i had a good bounce on it and it doesnt touch the underneath !!!
Yeah i thought i would go for white something different my paint job will tie in with the white frame red spokes etc theme !!!
Offline Ewan 500 K1
« Reply #4 on: September 21, 2013, 10:51:45 PM »
'mon the Dons :)
« Last Edit: September 21, 2013, 10:57:41 PM by Ewan 500 K1 »
Offline UK Pete
« Reply #5 on: September 23, 2013, 07:12:44 PM »
That looks great stuart all your hard work is starting to pay off
Pete
Offline cb750stu
« Reply #6 on: September 23, 2013, 09:10:08 PM »
Cheers Pete im glad i took my time with her going to start on my wiring and run all the cables tomorrow so hopefully by next week she should be running!!!
Still cant decide on the colour scheme ive got so many ideas !!!
