Hi Folks just thought i would post some pics of my build progress !!
The frame went in no problem using the lower the frame down over with the engine on its side method !!!
Swingarm wasnt easy its a tight fit my 5 year old son helped me !!!
Carbs went on quite easily with the help of a smear of Fairy liquid and new carb rubbers!!!
I know it looks like thers not much room between the top of wheel and frame but its resessed underneath i have 4.5 " to play with and the suspension is pretty stiff lol
Couple of questions if you dont mind ??
Am i best to fit the front calipers before the wheel or vice versa ??
When i tried to fit the front wheel there is still play from side to side does the hex part of the spindle nut go to the outside or inside ??Anyway ill keep posting pics of my build !!
Cheers Stuart
