Author Topic: Battery hook up ??  (Read 3597 times)
Offline cb750stu
Battery hook up ??
« on: October 09, 2013, 07:28:20 AM »
Hi Folks,
CB750 F1.
Just a few questions about hooking up my battery if you dont mind ??
Am i right in saying that the
the battery cable from the engine goes to the starter solenoid which side the solenoid is not marked ??
Then the short battery cable (positive) which connects to the loom goes to the other connection on solenoid ??
Then the frame ground goes to the negitive on the battery ??
What goes onto the positive on the battery ??
Cheers    Stuart
1976 CB750 F1 SS in bits !!! but getting there
Offline mickwinf
Re: Battery hook up ??
« Reply #1 on: October 09, 2013, 08:31:36 AM »
there should be a heavy cable from the pos terminal of the battery to the other terminal on the solenoid, when you press the starter switch the solenoid is energised so making the connection between the battery and starter motor. the cable from the loom supplies normal current for ignition, lights etc.
Offline cb750stu
« Reply #2 on: October 09, 2013, 05:29:59 PM »
Cheers I must be missing a cable I only have the starter cable from the engine to solenoid, the short cable to the loom and solenoid and the negitive to frame (big terminal lug)  I must be missing the positive from battery to solenoid ???
Stu
Offline cb750stu
« Reply #3 on: October 09, 2013, 06:47:08 PM »
Found it I thought I was missing something  :D
I am going to need to extend the starter cable can I splice another piece of cable to make it longer ???
Offline cb750stu
« Reply #4 on: October 09, 2013, 06:51:45 PM »
Refrence the negitive cable to engine ???
Can I ground it to anywhere on the frame ??
Offline cb750stu
« Reply #5 on: October 09, 2013, 07:30:45 PM »
Yeah my solenoid is under my seat now along with everything else !!!
Is it a easy job to remove the starter motor ???
I can easy cut the earth neg cable and put a smaller lug on it I've got a place in mind for mounting it
« Last Edit: October 09, 2013, 07:58:18 PM by cb750stu »
« Reply #6 on: October 09, 2013, 09:37:32 PM »
The earth lead goes to an engine mount, where incidentaly the paint is removed from both sides, so that the large starter current has an appropriate sized cable.
I have seen looms melted when the engine plates have been powder coated or painted and full starter current has passed along the small green wire on the loom
Offline cb750stu
« Reply #7 on: October 09, 2013, 09:46:08 PM »
Cheers guys I've taken the PC off to bare metal and secured with a new nut and bolt !!!
