Author Topic: Leaky tank  (Read 4369 times)
Offline Norniron
Leaky tank
« on: January 19, 2014, 04:41:55 PM »
I took off my carbs today to finally clean the emulsion tubes and an hour later job done.but then i discovered this.damn it.bottom left corner of the tank is starting to leak.
1977 400 cafe
1972 500/4
2013 triumph STR675
Offline billy192
    • Shermonkel
Re: Leaky tank
« Reply #1 on: January 19, 2014, 05:22:24 PM »
Ii had a leak in my Kawasaki S3 tank a tiny pin hole so I used POR 15, it has worked great. I did it 12 months ago and it is holding up ok.
BILLY
Billy
Offline Norniron
Re: Leaky tank
« Reply #2 on: January 19, 2014, 05:40:46 PM »
I used Petseal about 2 years ago.will give it another go
1977 400 cafe
1972 500/4
2013 triumph STR675
Offline Green1
Re: Leaky tank
« Reply #3 on: January 19, 2014, 06:25:57 PM »
Don't use petseal it brakes down because of the methanol in the fuel
Mick
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Honda CG125
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline Norniron
Re: Leaky tank
« Reply #4 on: January 19, 2014, 07:13:58 PM »
Thanks green
1977 400 cafe
1972 500/4
2013 triumph STR675
Offline LesterPiglet
  • 1977 CB550F2
Re: Leaky tank
« Reply #5 on: January 26, 2014, 05:33:17 PM »
Are you repainting the tank? My old S1 got a leak and I brazed it.
Offline Norniron
Re: Leaky tank
« Reply #6 on: January 26, 2014, 08:36:32 PM »
No shouldn't have to because the chrome strip should hide any marks.gonna give that por 15 a go.
But if it needs painted it wont be a big deal.
1977 400 cafe
1972 500/4
2013 triumph STR675
59viperman
Re: Leaky tank
« Reply #7 on: January 26, 2014, 08:53:17 PM »
 ;) my velo had a four inch crack in it [and I mean a proper crack] was told by an old boy use araldite, I was very sceptical to say the least but that was two years ago and no probs. trick is leave at least a week to go rock hard [ two would be better] then rub it down for paint. you cant even see it on mine.
Offline Norniron
Re: Leaky tank
« Reply #8 on: January 26, 2014, 08:58:17 PM »
Cheers viperman
1977 400 cafe
1972 500/4
2013 triumph STR675
59viperman
Re: Leaky tank
« Reply #9 on: January 26, 2014, 09:45:16 PM »
 :-[ ohhh!! I've gone all a quiver, that's the first time I have ever made a constructive contribution .  8) it wont last.
Offline Norniron
Re: Leaky tank
« Reply #10 on: February 21, 2014, 07:29:35 PM »
Do u have to go through the three part process when using this por15.
Or do u think theyre tryin it on to sell more products.
1977 400 cafe
1972 500/4
2013 triumph STR675
Re: Leaky tank
« Reply #11 on: February 21, 2014, 07:36:04 PM »
What are you going to do with that? You can not fix a leak with a tin of paint. Get the tank brazed, and then paint it.
Offline Norniron
Re: Leaky tank
« Reply #12 on: February 21, 2014, 07:43:18 PM »
This stuff is supposed to be the dogs danglers
1977 400 cafe
1972 500/4
2013 triumph STR675
Re: Leaky tank
« Reply #13 on: February 21, 2014, 07:46:14 PM »
Heard all that b4.Any proof out there?
Bitsa
Offline Norniron
Re: Leaky tank
« Reply #14 on: February 21, 2014, 07:50:16 PM »
Bitsa
Just wot ive read on this forum,but im tryin to save repainting
1977 400 cafe
1972 500/4
2013 triumph STR675
