Author Topic: Chain breaker Rivet tool ??  (Read 5440 times)
Offline cb750stu
« on: January 22, 2014, 07:47:37 AM »
Hi Folks,
Just wondering if anyone can recommend a good chain tool there are loads out there but most of the ones look like they would break just by looking at them !!!
Also I'm after a good spark plug socket it took me ages last night to change 4 plugs on my 76 750 F1,
Cheers,
Stuart
1976 CB750 F1 SS in bits !!! but getting there
Re: Chain breaker Rivet tool ??
« Reply #1 on: January 22, 2014, 09:37:21 AM »
Hi Stu.
Middle 2 a bastard.I found that my Yam XJR1300 albeit shorter was good at getting them out as it has a spanner head whereas the honda one has a hole through it.Just do not over tighten with the spanner head.Bryan may remember if I am right but Honda had a two piece plug tool that was bloody good a bit like the one in the photo.The one in the photo is ok for the outer ones and ok for all when the engines out,hope this helps.
Bitsa
« Last Edit: January 22, 2014, 10:44:05 AM by Bitsa »
Offline matthewmosse
« Reply #2 on: January 22, 2014, 10:12:47 PM »
I use an angle grinder to knock the rivett heads off and punch them out with a parrelell pin punch if shortening. If joining a rivett chain I pein the rivetts over carefully using a hammer. That said I prefer the old split link chains and lower hp bikes (cb550 being the biggest chain bine I have owned). If you have something modern and sporty then perhaps the proper tool might be worthwhile.
Offline Waggles
« Reply #3 on: January 23, 2014, 11:47:14 AM »
I have a rivet tool that worked OK but have only used it once so can't really say how reliable it will be over time. Will try and remember / find out where I got it. Think most are broken when trying to remove a link, the instructions with mine said you should grind the head off first, seems sensible.
As for plugs I use the socket from the original tool kit. Yes the middle two are a bit fiddly but not too bad if you don't over tighten ( quarter turn only )
« Reply #4 on: January 23, 2014, 01:48:11 PM »
I haven't done the plugs on a 750, but on my 550's I found a draper one was just about able to get in there to do the job, but might well decide since I have 2 I may turn the shoulders off the spare in my lathe to inprove access - the main issue was the sockett getting stuck in there and dropping off the extension bar.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #5 on: January 23, 2014, 08:19:02 PM »
Get the correct Honda plug spanner from Silvers, you won't regret it.
Is the 750 different to the 550 in that regard?
« Last Edit: January 23, 2014, 08:22:43 PM by LesterPiglet »
Offline Norniron
« Reply #6 on: January 23, 2014, 09:27:14 PM »
Does anyone have the part number for the plug spanner?
1977 400 cafe
1972 500/4
2013 triumph STR675
  • 1977 CB550F2
« Reply #7 on: January 23, 2014, 09:43:36 PM »
550 is 89216323000
http://www.davidsilverspares.co.uk/parts/by-part-number/partnumber_4826/
So far I've discovered it fits 500/550/650 and 750. Still checking.
« Last Edit: January 23, 2014, 09:47:13 PM by LesterPiglet »
Offline Norniron
« Reply #8 on: January 23, 2014, 10:00:27 PM »
Thanks lester.just ordered one £14.10.no more arsein about with box spanners.
1977 400 cafe
1972 500/4
2013 triumph STR675
Offline Norniron
« Reply #9 on: January 23, 2014, 10:02:49 PM »
Sorry stu for the hijack!
1977 400 cafe
1972 500/4
2013 triumph STR675
Offline cb750stu
« Reply #10 on: January 23, 2014, 10:05:01 PM »
No worries man I've just ordered one as well cheers
  • 1977 CB550F2
« Reply #11 on: January 23, 2014, 10:07:33 PM »
Well I've just discovered the one for the 400 is different.  :-\
Different part number anyhoo. May be the same tool.
http://www.gearhead.com/honda-99004-18002.html#/s/HOM//99004-18002/1
« Last Edit: January 23, 2014, 10:21:17 PM by LesterPiglet »
Offline Norniron
« Reply #12 on: January 25, 2014, 08:38:30 PM »
They are les,left is the 400 tool and 550 to right
1977 400 cafe
1972 500/4
2013 triumph STR675
« Reply #13 on: January 25, 2014, 10:54:08 PM »
How did this get on to spark plug sockets? What happened to the chain rivet tool?
Offline Norniron
« Reply #14 on: January 25, 2014, 10:55:59 PM »
Hijack trigger
1977 400 cafe
1972 500/4
2013 triumph STR675
