Author Topic: f mudguard stay  (Read 2600 times)
Offline billy192
    • Shermonkel
f mudguard stay
« on: January 24, 2014, 05:05:16 PM »
fitting my front mudgaurd and not sure if the bracket goes behind the caliper carrier or on top?
Billy
Billy
Offline mick
Re: f mudguard stay
« Reply #1 on: January 24, 2014, 05:29:29 PM »
That's right how you have it now  ;) cheers Mick.
Offline billy192
    • Shermonkel
Re: f mudguard stay
« Reply #2 on: January 25, 2014, 08:28:57 PM »
optical illusion Oddjob went in sweet,  ;D ;D ;D
Billy
Offline Waggles
Re: f mudguard stay
« Reply #3 on: January 29, 2014, 09:55:02 AM »
If you get it wrong the front brake goes out of line and binds. Don't ask me how I know
Offline billy192
    • Shermonkel
Re: f mudguard stay
« Reply #4 on: January 29, 2014, 04:45:43 PM »
the caliper carrier does seem out of line. it needs to be closer to the fork, i think :-[
as if it is too far toward the spokes :-\ :-\ :-\ any ideas
Billy
Billy
Offline billy192
    • Shermonkel
Re: f mudguard stay
« Reply #5 on: January 29, 2014, 04:52:46 PM »
can the carrier bracket be on the wrong way round?
Billy
Billy
Offline billy192
    • Shermonkel
Re: f mudguard stay
« Reply #6 on: January 29, 2014, 06:26:37 PM »
new honda part, same length as the old one. i can adjust and pull over 8 mm but it seems to be at angle as if either the disc is to close to the fork or the carrier is to far to the left  :-[ :-[ :-[
Billy
Billy
Re: f mudguard stay
« Reply #7 on: January 29, 2014, 06:59:28 PM »
Hi Billy.
Should look like this, something is not assembled right
Bitsa
Offline billy192
    • Shermonkel
Re: f mudguard stay
« Reply #8 on: January 29, 2014, 07:18:19 PM »
Bitsa your the best,
mine is exactly the same but for the washer on the tensioner screw. i an happy now thanks
Billy
Billy
Offline LesterPiglet
  • 1977 CB550F2
Re: f mudguard stay
« Reply #9 on: January 29, 2014, 07:23:45 PM »
I'm not sure how the washer makes any difference.
Re: f mudguard stay
« Reply #10 on: January 29, 2014, 07:31:39 PM »
Billy,
If its on the parts list you fit it the same way see www.cmsnl.com/honda-cb750k6-four-france_model14385/partslist/F08.html#results
Should be the same for all countries.Forgot to add mine has brand new pads in it as they wear the holder when adjusted right moves over the disc more.
Bitsa
« Last Edit: January 29, 2014, 07:35:53 PM by Bitsa »
  • 1977 CB550F2
Re: f mudguard stay
« Reply #11 on: January 29, 2014, 07:46:13 PM »
I'm not saying adding the washer is wrong, I just don't understand how it can affect the angle.
Offline billy192
    • Shermonkel
Re: f mudguard stay
« Reply #12 on: January 30, 2014, 01:11:14 PM »
ok I must be confusing people  ;D
it IS a 750 K6
I asked if (in the pic below) it was correct to be off set, the carrier to the left of the disc. as I assumed it should be directly over the top of the disc.
but Bitsa sent a Pic of his 750 and it is exactly thew same as mine. But for the washer, which i know makes no difference to the alignment.
so if you look at bith pics they are off set toward the left.  ;D
so i am happy now.
Billy
thanks for all the help
Billy
Offline billy192
    • Shermonkel
Re: f mudguard stay
« Reply #13 on: January 30, 2014, 02:58:32 PM »
i don't have a 350/4  ;D ;D
Billy
