Author Topic: 400/4 Front Mudguard  (Read 2875 times)
Offline Drew400
  • 400/4 I restored
« on: January 28, 2014, 03:45:56 PM »
My 400 has a front mudguard with only one pair of support struts behind the fork leg. All the pictures I've seen of 400/4s have two pairs of struts supporting the mudguard, i.e. one pair in front of the fork leg too. I'm guessing that mine is an after-market part, especially as there is no evidence of tampering or that more supports we're ever present. Expert advice much appreciated, thank you. Drew.
Offline LesterPiglet
  • 1977 CB550F2
Re: 400/4 Front Mudguard
« Reply #1 on: January 28, 2014, 04:58:51 PM »
I found this from here http://www.motorera.com/honda/h0400/four.htm
No other info I'm afraid.
« Reply #2 on: January 28, 2014, 05:09:11 PM »
Do not worry Drew, some do, some don't. I have seen many with only one strut. I have a CB550 with one.
  • 1977 CB550F2
« Reply #3 on: January 28, 2014, 05:29:25 PM »
I'll do you a swap.  :P
« Last Edit: January 28, 2014, 05:31:48 PM by LesterPiglet »
« Reply #4 on: January 28, 2014, 05:36:13 PM »
It's probably original, the CB750F1 started life with 1 brace, and part way through production it changed to 2 braces ;D
Offline Clem2112
  • Midlife
« Reply #5 on: January 29, 2014, 05:01:39 PM »
Think the UK 400/4 always had front and rear stays  - F, F1 and F2
Many U.S. Bikes seem to have just the rear stay type.
Offline Drew400
  • 400/4 I restored
« Reply #6 on: January 29, 2014, 06:16:32 PM »
Thank you all. I'll stop worrying about its originality and start worrying instead about the cost of fettling! Cheers, Drew.
Offline Piki
« Reply #7 on: January 29, 2014, 06:45:24 PM »
I think that the originals have two stays. The originals has stamped on the bottom 370(on the middle of front guard).
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #8 on: January 30, 2014, 01:53:29 AM »
Drew,
From the Honda 400F parts manual... your mudguard is correct.
This is a late American F2 spec.  (the 'A' implies American spec)
Simon
Offline ashewan
« Reply #9 on: February 01, 2014, 11:26:20 AM »
Hi,
I've only put the rear strut on my front mudguard, although the mudguard is drilled for the front strut as well.
Its also drilled to take the vertical style front number plate which might explain the need to add the extra bracing at the front.
Offline Drew400
  • 400/4 I restored
« Reply #10 on: February 02, 2014, 03:34:47 PM »
Thank you all again, especially Simon... parts manual picture, hmmm, very impressive! I now need to clean off all the crap to see if I can find '370' somewhere.
I'm now moving on to my next query which I'm guessing web chat protocol requires me to start anew. So, I think it's time to close off this particular query.
Cheers, Drew
