Author Topic: 410 cylinder head  (Read 957 times)
Offline r1_pete
410 cylinder head
« on: February 05, 2014, 06:24:41 PM »
I have what is clearly a bitsa engine, it has K cases with the narrow / hollow gearbox output shaft, but has a 410 head.
The head is not black and shows no sign of ever being black, did Honda use the 410 casting in silver on any other model?
I'm planning to build the whole lot into some K7 cases, because I have a mint set and want a silver engine, any gotchas fitting the 410 head / barrels onto K7 cases?
2009 Yamaha XJR1300 sold
1977 CB750F2 café racer project. Sold
1972 CB750K2 hot rod. Sold
and an E-Type Jaguar that considers itself worthy of all my spare cash. Sold
1971 CB450
1978 Reliant Scimitar Cosworth.
Offline UK Pete
Re: 410 cylinder head
« Reply #1 on: February 05, 2014, 07:27:33 PM »
410 head is f2/3 , You must have the f2 barrels as well because the k barrels dont work with the f2 head
I have a k7 bottom end which i was going to put an f2 top end on, it seems that the k7 lower end is similar to the f2 with the beefed up output shaft, if you are going to mix and match do a bit of research as some things wont work without modifications
« Reply #2 on: February 05, 2014, 10:22:39 PM »
I've got an official Honda shop manual that has F2 and K7 as a pair.
The whole manual essentially deals whith them as the same bike apart from the obvious differences.
It looks like the bottom ends are the same and the cylinder head casting also....the K7 being silver (no paint) and having smaller valves than the F2.
Nigel.
« Reply #3 on: February 06, 2014, 10:05:04 AM »
If I recall correctly the K7 used the F1 engine but with the later F2 type carbs with accelerator pumps
Sent from my GT-S5839i using Tapatalk 2
