Author Topic: My version of a Hydraulic clutch conversion  (Read 1462 times)
Offline r1_pete
« on: February 22, 2014, 02:16:49 PM »
I fancied having a go at a hydraulic clutch for a while, no real reason other than to be a bit different, I've seen many using a triangular type plate, but couldn't see how it was centred....
So came up with this, which centres on the original cover lip, I'm quite pleased after 3 or 4 hours on the lathe its turned out perfectly centred.
Next job is to plug the kickstart hole, then start polishing.
2009 Yamaha XJR1300 sold
1977 CB750F2 café racer project. Sold
1972 CB750K2 hot rod. Sold
and an E-Type Jaguar that considers itself worthy of all my spare cash. Sold
1971 CB450
1978 Reliant Scimitar Cosworth.
Re: My version of a Hydraulic clutch conversion
« Reply #1 on: February 22, 2014, 04:58:17 PM »
Really nice work there pete. What's the donor hydraulic actuator from?
Offline MarkCR750
« Reply #2 on: February 22, 2014, 06:21:55 PM »
Excellent job, have you removed the kick start permanently?.
Suzuki GT250A (Nostalgia)
Ducati 900SS (Soul & Speed)
Thruxton 1200 (suits me)
Sir J.Stewart.
« Reply #3 on: February 22, 2014, 06:33:49 PM »
Nice bit of lathework there! But, I am very curious as to how the oilpump is going to work without the kickstart shaft, have you shortened the shaft, or some other incredibly cunning plan?
Offline r1_pete
« Reply #4 on: February 22, 2014, 07:48:52 PM »
The slave is from a CBR1000 but its pretty common across the Honda range.
The kick starter will be permanently removed, I'm going to cut the shaft a couple of mm short of the oil seal and press in an alloy blanking plug with a smear of Loctite.
1971 CB450
« Reply #5 on: February 22, 2014, 09:15:18 PM »
Nice work Pete.
Offline Eric Frith
« Reply #6 on: March 05, 2014, 10:49:37 AM »
Excellent.....
