Author Topic: wiring and cable routes pics  (Read 2762 times)
Re: wiring and cable routes pics
« Reply #15 on: February 23, 2014, 10:50:30 PM »
Fine sand paper or wire wool will do the job.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #16 on: February 23, 2014, 11:43:15 PM »
I believe soak them in vinegar then brush with a fine wire or toothbrush. I've never taken mine apart, but if you have all the time in the world.  ;)
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #17 on: February 24, 2014, 12:03:14 AM »
If you dismantle the plugs be sure to take a photo before, else risk incorrect / mis wired reassembly!. And whilst you can clean the male connectors, you'll achieve little if the females can't be serviced (ooh!).
A mild & agitated acid bath as Lester suggested, in perhaps a cheapo ultrasonic cleaner - if you have one - might be an alternative, followed by a good wash with brake cleaner spray.
A tip for when you 'power up' first time, and assuming your fuses are nice motorcycle / Honda ones... replace them with household fuses of similar rating (eg 13A instead of 15A) ... until you sort all / any issues out.
Offline MikeM
« Reply #18 on: February 24, 2014, 08:22:07 AM »
I cant even ride the bike if it was finished, done my mod 1 awaiting to take mod 2
I have another bike which I use at the moment, just want the bike to be clean and run well and thought electrical contacts would be  good place to start to make sure of this
