Author Topic: Help, electric guru needed  (Read 1591 times)
« on: April 05, 2014, 03:24:17 PM »
I have a electric ignition with 3 wires Blue, Yellow and black. The wires on the loom are Green with Yellow stripe and a Black. Could anyone advise on what colour wires connect to what colour wires?
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Re: Help, electric guru needed
« Reply #1 on: April 05, 2014, 05:15:38 PM »
Hi Trig,
Ain't no elect guru... but enjoy fiddling. Also, am very much aware the Honda wiring can change over models etc... but most likely...
Your loom.  The BLACK is likely a switched live... ie is 12V +ve @ all times the ignition is switched ON.
The green / yellow stripe is the switched feed to the brake light, with the switch being either the front or rear brake switches. So... black live into those switches... you brake.... and now the 12v continues down the green / yellow to the brake lamp... through this & completes the circuit to earth.
The electronic ignition needs a 12v supply.... and so you need to connect your loom BLACK to its BLACK. This BLACK elect ign feed is typically taken from the Honda rear brake switch which is the closest / easiest power take-off to the points plate. You need to disconnect the BLACK bullet connector to the rear brake switch, and insert a 'Y' feed, ie so the loom BLACK now supplies both the brake switch AND your electronic ignition. (this 'Y' feed wire is typically supplied with the electronic ignition kit - tho you can easily fabricate one assuming you have bullet connectors etc).
The GREEN / YELLOW simply connects as standard, ie the other wire out of the brake switch.
(the brake light switch has two wires, and nope, it doesn't matter which way 'round they're connected to the BLACK & GREEN / YELLOW loom connectors. What does matter is that the BLACK loom is used to feed the BLACK elect ign.)
Which leaves the electronic ignition BLUE & YELLOW.... and these are connected to the respective BLUE & YELLOW wires of the L & R coils.... which should be down in the points housing & previously connected to the deleted points.
This may be your system set-up.... expand the Instructions leaflet.
http://www.cmsnl.com/cb550k3-four-england_model14671/ignition-assyelectronic-kokusan_03020300505/
Hope this all makes sense,
Simon.
« Last Edit: April 06, 2014, 04:14:23 AM by Lobo »
« Reply #2 on: April 05, 2014, 05:47:41 PM »
Cheers Lobo, yes it is the same ignition as in the link. That makes things a little clearer but, black to black (live feed) now i am left with 1 Blue and 1 yellow and only have 1 Green with yellow stripe. Two can't go into one. Are you saying to run the yellow and blue up to the coils?.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #3 on: April 05, 2014, 05:59:43 PM »
Yes. The blue and yellow feed the points. The connectors are behind the carbs. So when you disconnect the points these will be free.
« Reply #4 on: April 05, 2014, 09:04:32 PM »
YES, I know i am crap at electrics.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #5 on: April 06, 2014, 03:34:05 AM »
So, what you should now have is this...
« Reply #6 on: April 06, 2014, 09:22:26 AM »
Got it. Cheers Lobo :) There will be more wiring questions to come, so don't go away.
