Author Topic: CB550F Double Disc's  (Read 16034 times)
Offline Ewan 500 K1
  • jings crivens help ma boab
    • Adams Bros Probe 2001
Re: CB550F Double Disc's
« Reply #45 on: April 21, 2014, 08:55:22 AM »
I am working from this:
http://www.salocal.com/sohc/tech/dual_disks/dual_disks.htm
 that explanation/advice is so good,I hadn't found that,but its almost 100% what I ended up doing,
yep he's got it wrong about the unmodified spedo drive plate. The alternative to the one in oddjobs link is to modify the drive plate as per attached photo, ie cutting off excess and then bending over two tangs to fit the flats on the hub. Original drive plate on the right, modified one on the left.  But.... this only works if have a hub with the flats on it, like the one in the second attached picture
[ Guests cannot view attachments ] , [ Guests cannot view attachments ]
Also ,  like oddjob, I fitted the mudguard stay between the pivot arm bracket and the fork tube .... didnt need to use any shims or file anything to get the pads sitting parallel with the disc
I do still need to find a longer adjuster bolt as oddjob suggests
« Last Edit: April 21, 2014, 09:19:18 AM by Ewan 500 K1 »
500K1 basket case for later
« Reply #46 on: April 21, 2014, 09:25:03 AM »
Now I did my first twin disc using two 500 sliders which put one caliper in front and one behind and altered the muguard mount by carfully cutting off the psrt with the bolt holes , turning it round and welding it back on. Don't ever remember shimmng anything and everyhing worked ok.
Later rebuit it with a 550 sider when they came avaiabe used but still dont remember any shimming.
I bought a genuine part speedo drive as it is the very eary 750 one that is needed and have still got one NOS for one of my projects which i wi happily take pictures of and measure but not sell I also used a girling master for an eary GL1000 which was identical to the Honda part as this meant the lever did not travel so far back before the brakes worked.
All this was back in the 76/77/78 era so don't ask for any better descriptions, the only other thing i remember is finding out the steering stem was bent where it went into the lower yoke as when I used the brake hard the mudguard came up between the two centre pipes of the (Very Loud) Marvin exhaust system so no matter what you wanted to do you went straight on, as the IOM plod found out just before he dived over the wall at Glen Helen---I let the brake off and just got round, always hated my mates GS750 after that as there was no front brake operated brake light!!!
Offline Ewan 500 K1
« Reply #47 on: April 21, 2014, 09:48:05 AM »
part number 44641-300-000, as shown  ????. Think its unavailable now, but an be copied by modifying a stock 500 / 550 one as my post above
« Last Edit: April 21, 2014, 09:51:12 AM by Ewan 500 K1 »
« Reply #48 on: April 21, 2014, 09:30:53 PM »
Yes Ewan, had noticed it on your post. Was trying to work out if this bloke from Salocal put the drive plate in and then just crushed it by pulling it in by tightening up the disc bolts :-\
Offline Ewan 500 K1
« Reply #49 on: April 21, 2014, 11:02:54 PM »
« Reply #50 on: April 22, 2014, 12:16:43 AM »
I managed to get the original speedo drive from CMSNL.com   last year,
 they had several in stock,
 and I did have to trim the outer of it,and also file the disc carrier to take it
« Reply #51 on: April 22, 2014, 06:01:48 AM »
Now you say that i remember having to take small amounts out of the disc carrier centre to make rectangular holes for the drive Tangs
Offline Ewan 500 K1
« Reply #52 on: April 22, 2014, 06:50:29 AM »
I suppose a Q for trigger would be ... what kind of front hub do you have ... is it the version with the two flats on it (see photo in my post above) .. or the version without the flats ?
« Reply #53 on: April 22, 2014, 07:50:36 AM »
Ewan, I have the same hub as showing in your post.  Oddjob, i was only joking about pulling it in on the disc bolts. You are right, how the hell did he do it without any mods? I think he was telling porkies.
Offline matthewmosse
« Reply #54 on: April 22, 2014, 10:06:02 AM »
I did a twin disk setup on one of my cb550k3's many moons ago, I used comstar front wheel though so no usefull hints off that other than that I think I used a stock master cylinder, worked ok for a commuter, to be honest though I think a single disk works pretty well anyway - I coud lock the front tyre even with a sidecar fitted, the stainless disk was the thing I might change if looking for inprovement, but only during rain as I used to have to lightly apply the front brake all the time in a downpour if I wanted it to work immideately on demand. Once you master the mindset of doing it it was second nature to keep light braking pressure on 200 yards before every bend or blind spot. I do know that my bmw of the same era had the same issue, though less as twin disked and drilled from the factory and for these you could buy pfm performance disks which  being cast iron looked horrid at the mere mention of rain but gave better braking. I had a set but never used them.
Offline Ewan 500 K1
« Reply #55 on: April 23, 2014, 10:38:35 PM »
Then I think you just need to make the one on the right into the one on the left,
CMSNL are out of stock of the original part http://www.cmsnl.com/products/retainer-gear-box_44641300000/
Mount the mudguard bracket BETWEEN the fork and the brake pivot arm bracket and you wont need any shiming or shaving. You'll need some goldwing disc bolts. Less sure about the master cylinder , but I had a goldwing one (retangular kind) to hand anyways so used that.
You might also find that the speedo cable rubs off the new disc so will needd to do summat about that.
« Last Edit: April 23, 2014, 10:51:57 PM by Ewan 500 K1 »
« Reply #56 on: April 23, 2014, 10:46:34 PM »
Seems straight forward Ewan. Have loads of bolts in stock, was going to use some 110mm 8.8.
Offline Ewan 500 K1
« Reply #57 on: April 23, 2014, 10:53:50 PM »
Maybe need to be Jap spec for smaller diameter head size (12mm ) ... or was it a shallow enough head depth to allow the bolt heads to clear under the speedo drive ... was one or the other or maybe both ;)
.. also was advised not to use stainless bolts as they cant take the shear stresses
John W did a conversion recently and had to do a bit of shimming ... but think he mounted the mudguard braket ON TOP of the pivot arm bracket ? .. also (strangely ??) John had to take some material off the disc to allow the standard 44641-300-000 speedo drive plate to fit. I never had to do that to my modified one.
Also, there's two versions of the speed drive plate that has the lugs that fit in the chrome cover ( ie the one I modified). One is solid and one is a two part one with the two parts joined with rubber. I used the former to make my equivalent 44641-300-000.. if I recall correctly I seem to remember seeing somewhere that you cant use the two part one to modify to a 44641-300-000 shape (maybe because the heat from the grinder would melt the rubber ?? )
« Last Edit: April 23, 2014, 11:16:14 PM by Ewan 500 K1 »
« Reply #58 on: April 23, 2014, 11:24:09 PM »
No rubber Ewan, looks spot on to yours. I think m8 x 110 high tensile steel bolts should be up to the job.
« Reply #59 on: April 24, 2014, 09:10:07 AM »
All i used eons ago, wing ones might be prettier as they are polished/chromed
