Author Topic: Rocker cover tightening seqence ?  (Read 1882 times)
44fellow
« on: April 16, 2014, 05:18:29 PM »
Hi y'all,wondered if anyone can help me out with this one,my Haynes manual page 54 only gives the sequence for 7 of the 22 bolts on the rocker cover so what order are the rest to be tightened to,cheers
Re: Rocker cover tightening seqence ?
« Reply #1 on: April 16, 2014, 05:40:53 PM »
From the center, moving out. Would help if i knew for what engine.
44fellow
« Reply #2 on: April 16, 2014, 05:51:35 PM »
sorry,its a 400/4
« Reply #3 on: April 16, 2014, 07:04:28 PM »
Hope this works. This shows you:
http://manuals.sohc4.net/CB350_CB400/CB400_CB350_SM_1.pdf
Page 16
« Reply #4 on: April 16, 2014, 08:46:50 PM »
44fellow, does that help? page 17. Hope this helps.
44fellow
« Reply #5 on: April 16, 2014, 09:36:07 PM »
Yeah,but not the full monty,I've got that manual also,just wondered why it only shows the sequence for seven bolts, ink famine or what?,just dont want to buckle the cover so I'll take your advice and work from the centre out.....kinda,thanks for the help...cheers buddy.
« Reply #6 on: April 16, 2014, 09:43:21 PM »
You just extend the sequence in a X pattern going out. Never seen a 400/4 Manuel until i just looked it up for you. Lost count on how many i have built over the years.
44fellow
« Reply #7 on: April 16, 2014, 09:59:34 PM »
Top man,consider it done,thanks again.
ka-ja
« Reply #8 on: April 17, 2014, 07:18:41 PM »
Hi Trigger,
                Thanks for the link-might come in useful-----Ken
