Author Topic: cb750 cam timing  (Read 3327 times)
750rideruk
cb750 cam timing
« on: April 18, 2014, 06:37:53 PM »
On rebuilding my cb750 K1 I find that on lining the T mark 1-4 up the cam line is slightly out of level but not as much as one tooth on the camsprocket. I have fitted a new cam chain. Anyone with any ideas or is it OK to continue?
Re: cb750 cam timing
« Reply #1 on: April 18, 2014, 06:59:35 PM »
Is this with the tensioner fitted?Photos of the T mark and the cam would help.If you have not got the tensioner on with the difference you describe could be it.
Bitsa
750rideruk
« Reply #2 on: April 19, 2014, 11:15:28 AM »
Only very slightly out of line. is this OK
Offline tom400f
« Reply #3 on: April 19, 2014, 12:45:11 PM »
Bitsa is suggesting that backlash in the chain, if it is not tensioned, might account for the discrepancy. Perhaps wind the engine backwards some way then approach the timing marks in the correct direction of rotation only. Do they line up then?
1978 CB400F2 Yellow
1995 VFR750FS Red
1997 VFR750FV Lapis Blue
2013 Yamaha FZ8 Grey
750rideruk
« Reply #4 on: April 19, 2014, 04:26:40 PM »
I have tried that to no avail. Atiming disc show about 15 degrees out but not as much as one tooth on the camsprocket. Starting to think its a faulty chain but seems a bit far fetched
« Reply #5 on: April 19, 2014, 06:59:36 PM »
Photos and will let you know.Why are you using a timing disc for?Hondas have it all there for you.
Bitsa
« Last Edit: April 19, 2014, 07:11:55 PM by Bitsa »
750rideruk
« Reply #6 on: April 27, 2014, 12:51:41 PM »
Job sorted.
Cam chain had come off the crankshaft sprocket. Removed barrells and heads replaced and hey presto everything aligns
« Reply #7 on: April 27, 2014, 02:10:55 PM »
Yep
Had that happen to me once but with a lot of poncing about got it back on the crank without removing cylinders and head,
Well done hope all goes well for you,
Bitsa
Offline steff750
  • THE POWER OF DREAMS
« Reply #8 on: April 27, 2014, 08:32:56 PM »
 ;) yes we all done it I think at some time, but knowing it is off the sprocket is the trick I always try and keep tension on the chain so no slack is at the bottom of chain
 as bitsa says a lot of poncing about .
but it will go back on no problem without removing  the head or barrels
 but that being said you need to know that it is off the crank anyways ::)
« Reply #9 on: April 27, 2014, 08:37:12 PM »
Steff
Spot on mate I test it by pulling on the chain if its not on the crank it justs keeps pulling without any thing moving and hurts your hand like fury.
Bitsa
