Author Topic: front axel diameter?  (Read 1451 times)
Offline rickni
  • gettin there! it's always gettin there..
« on: May 02, 2014, 01:12:37 PM »
Need too order bearings! Anyone know Off hand is front axel 20mm for cb550...  Cheers
Offline rickni
Re: front axel diameter?
« Reply #1 on: May 03, 2014, 11:05:46 AM »
Thanks but am using a different make Off wheel! Outside diameter of bearing is 42mm,
Haven't bout an axel yet tho.
Offline rickni
« Reply #2 on: May 04, 2014, 07:55:42 PM »
thanks for the help!
anyone got an axel they could measure!
Offline rickni
« Reply #3 on: May 05, 2014, 07:04:04 PM »
Cheers thanks!
Offline ttr400
    • CB400F special machined parts
« Reply #4 on: May 07, 2014, 11:41:30 AM »
Just to clarify this before you buy the wrong bearings. the front axle is 15.0mm diameter and uses a 6302 bearing. this is also the same for the other Honda 4 models.
Kevin
If you are addicted to the little CB400F then you might want to check out my website.
www.ttr400.com
