Author Topic: Top yoke replacement  (Read 6372 times)
Offline El__burro
« on: May 08, 2014, 09:55:43 PM »
I am just looking at my new project (CB750 K2) and putting together a parts wish list.
I'll need some valve caps (the bolts that cover the valve)
I need also a top yoke, mine has a crack at the tightening bolt.
for sure I don't want to buy a similar one (with the rhino horn).
What other models do adapt to this model (even not Honda).
El__burro
Offline MarkCR750
Re: Top yoke replacement
« Reply #1 on: May 08, 2014, 11:04:42 PM »
EB, David Silver sells tappet caps and Honda CBX1000 Yokes are a straight swap, cheers Mark.
https://www.davidsilverspares.co.uk/CB750K2-FOUR-1972/part_105133/
« Last Edit: May 08, 2014, 11:18:29 PM by MarkCR750 »
Suzuki GT250A (Nostalgia)
Ducati 900SS (Soul & Speed)
Thruxton 1200 (suits me)
Sir J.Stewart.
Offline El__burro
« Reply #2 on: May 11, 2014, 10:26:11 AM »
Thanks Mark.
I am actually bidding on a 1978 CB750 F2 yoke,
will that fit?
El__burro
Offline MarkCR750
« Reply #3 on: May 11, 2014, 10:35:08 AM »
I don't know EB , hopefully someone else on the forum will.
Sir J.Stewart.
Offline El__burro
« Reply #4 on: May 15, 2014, 10:25:24 PM »
I'll let you know soon.
I paid £16 (incl P&P)
It's worth giving it a go.
El__burro
« Reply #5 on: May 16, 2014, 05:57:20 AM »
I thought that the F2 had bigger diameter fork tubes
Offline UK Pete
« Reply #6 on: May 16, 2014, 06:55:40 AM »
They are 35mm so should be the same dim
pete
Offline El__burro
« Reply #7 on: October 24, 2014, 05:19:02 PM »
Mark, is it just cbx1000 or also 750/500 models.
« Reply #8 on: October 24, 2014, 07:58:37 PM »
If you have the k2 clocks they will not fit on to nothing else except the rhino yoke hope you have considered this
Bitsa
Offline El__burro
« Reply #9 on: October 24, 2014, 08:02:27 PM »
My intention is to "shave off" the raisers as I have clip ons and the speedo mounted on the headlight.
The cbx one will be great as it will save me the shaving bit.
Regards
Offline El__burro
« Reply #10 on: February 10, 2015, 02:39:47 PM »
Mark, I bought a Honda Cbx1000 top yoke. It's not a straight swap.  Cbx  seems to have wider forks..
"thanks"
El__burro
« Reply #11 on: February 10, 2015, 03:44:39 PM »
I've got a CB750K7 top yoke ...don't know if it will fit.
Ash
Offline El__burro
« Reply #12 on: February 10, 2015, 06:17:36 PM »
Ash, i guess the k7 looks like the one i have already.
Unfortunately its not great for my purpose as i cannot shave the raisers off.
It would leave 2 huge holes.
Still the CBX one is perfect apart from the fork diameter variances.
Cb750 F2 (and k2) is 35mm
CBX 1000 IS 39mm
« Last Edit: February 10, 2015, 10:44:51 PM by El__burro »
« Reply #13 on: February 10, 2015, 06:51:43 PM »
Hi
I have a spare top yoke.Do not know whats its off but does fit the 750 with no problem think its 500 but not sure
If interested will post photo in the morning
Bitsa
Offline El__burro
« Reply #14 on: February 10, 2015, 06:54:11 PM »
Let's see it. Thanks to both of you.
I have just realised that also the CBX1000 one is 1 cm wider.
