Author Topic: exhaust stud coming out  (Read 743 times)
Offline MikeM
« on: May 15, 2014, 07:00:41 PM »
fitting exhaust and came up against a small issue, one stud on no 3 exhaust is coming out when I have fully tightened bolt on, when I take the nut off it pulls stud out
how can I get the stud all the way in ?
Re: exhaust stud coming out
« Reply #1 on: May 15, 2014, 07:18:46 PM »
Put two nuts on so one locks up against the other.Add a bit of retainer (if you have)  and wind it in.
« Last Edit: May 15, 2014, 07:23:44 PM by trigger6969 »
« Reply #2 on: May 16, 2014, 05:55:57 AM »
If you mean the stud is pulling out you will have to helicoil the hole
