Author Topic: CB550 Points  (Read 1029 times)
Offline Piki
CB550 Points
« on: May 16, 2014, 09:16:19 AM »
Hello, could I use the points and condesers (aftrmarket) from a 400 Four in my 550 Four??
Thank you in advance.
Offline kiwikk
Re: CB550 Points
« Reply #1 on: May 16, 2014, 09:55:06 AM »
Not 100% sure but couldn't you do a side-by-side comparison with a few dimension checks?
Failing that, I'd stick 'em in and see if you can gap them to spec and static time them with a light bulb.
A word of warning though.
If these aftermarket items are not TEC or ND brand, they could be difficult to set.
I've had to order some very expensive originals from David Silver 'cos the aftermarket ones were poor quality.
Good luck!
CB400F
CB-1
Re: CB550 Points
« Reply #2 on: May 16, 2014, 10:21:00 AM »
Yes, you can use them, but pattern points are nowhere near as good as O.E.
Sent from my GT-S5839i using Tapatalk 2
Offline Piki
Re: CB550 Points
« Reply #3 on: May 16, 2014, 12:00:19 PM »
Thank you hairygit, you are right, but the OE are very expensive!!! Do you know any alternative or any place where I can buy it with "lowcost"???
Offline Piki
Re: CB550 Points
« Reply #4 on: May 16, 2014, 12:27:04 PM »
Thanks kiwikk!!
