Author Topic: Cam info  (Read 2177 times)
Offline teebee67
Cam info
« on: May 26, 2014, 10:34:26 PM »
Hi,
I bought a used big bore kit off Ebay. With the kit was a camshaft which is marked on the end with H7Y. Can anyone identify the cam from this?
Any help much appreciated.
Cheers,
Tony
Re: Cam info
« Reply #1 on: May 26, 2014, 10:52:27 PM »
Tony, is the cam shaft from a CB550? I have seen his number on american cams.
Offline teebee67
Re: Cam info
« Reply #2 on: May 27, 2014, 08:30:26 AM »
Hi,
Sorry I should've stated it is from a CB750 SOHC.
Cheers,
Tony
Re: Cam info
« Reply #3 on: May 31, 2014, 04:34:57 PM »
Numbers on the end tend to be casting marks and mean nothing, some US makers mark the special cams but not many. All you can do is measure the lobes and compare to standard along with aftermarket "hot" cams
ka-ja
Re: Cam info
« Reply #4 on: May 31, 2014, 07:15:04 PM »
Hi,
    My 400/4 road/track cam has similar stamped numbers/letters on the timing end of the camshaft---ken
