Author Topic: wired for sound!  (Read 1298 times)
Offline honstan3
wired for sound!
« on: June 15, 2014, 12:44:49 PM »
hi to all, i wish to extend the rear indicators,on my 400/4, and im not to sure as to what amprage(excuse the spelling mistooks!) the wiring/cable should be?, i recently purchased some mini reels of cables from halfords, but as you can guess,plenty of amprage types. thanks.honstan3.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Wired for sound!
« Reply #1 on: June 15, 2014, 04:11:17 PM »
Hi Honstan..
Each indicator bulb will be about 5W, and given Volts x Amps = Watts you'll be needing cable of a minimum 0.5A rating......
BUT... (& check your fuse holder / owners manual) the fuse on this circuit is either rated at 7A or 15A... really meaning you should choose a wire rating higher than this so that the fuse melts first before any part of the indicator loom.
To check simply set the indicators going & pull the fuses in turn... when they stop you've found the circuit. If they're on the 15A circuit choose a wire rated better than 15A.... if they're on a 7A circuit choose a wire > 7A. Sorry can't be more specific... no access to a decent wiring diagram right now.
Hope this helps.
« Last Edit: June 15, 2014, 04:21:00 PM by Lobo »
Offline honstan3
Re: wired for sound!
« Reply #2 on: June 15, 2014, 04:51:07 PM »
many thanks for the advice, lobo, cheers.honstan.
Offline tom400f
« Reply #3 on: June 15, 2014, 07:32:41 PM »
Simon - you sure about 5W ? That is a tail lamp (with brake light often 18 or 21 W in the same bulb).... indicators are also 18 or 21 W (can't remember which)
1978 CB400F2 Yellow
1995 VFR750FS Red
1997 VFR750FV Lapis Blue
2013 Yamaha FZ8 Grey
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #4 on: June 16, 2014, 02:00:03 AM »
Aye carrumba! Quite right Tom, written at midnight after a few beers!
To correct myself Honstan the smallest wire rating you could use would be about 2A assuming an indicator lamp @ 21W. Sorry.
Rest of the 'fuse' ramblings stand.... ie choose wire rating better than fuse rating.
Thanks Tom,
Simon.
