Author Topic: lower engine case  (Read 1602 times)
Offline steven400/4
lower engine case
« on: July 23, 2014, 03:46:52 PM »
has anyone got a lower engine case they can look at i need to know somethink where you put the oil seal for the gear lever shaft where the seal fits into. at the bottom of mine theres like a cut out bit not very big need to know if it show be there you car,nt see it when the seal is in i,ve never notice it before when doing my engine,s
cb400f2 x7
honda ss 50
gsx 1400
Offline steven400/4
Re: lower engine case
« Reply #1 on: July 23, 2014, 08:16:25 PM »
looks like everyone is stump,d just wondering if it could be a oil way it looks like a hole if that helps if anyone could confirm if that a poss
cb400f2 x7
honda ss 50
gsx 1400
ka-ja
« Reply #2 on: July 23, 2014, 08:29:32 PM »
Hi,
     I just assumed it was an oil drain back into the "sump", as the casting on the inboard of the seal a machined finish supporting the gear change shaft at very near shaft diameter
Offline steven400/4
« Reply #3 on: July 23, 2014, 10:45:24 PM »
thanks it looks like a oil drain i must of court the seal when i was putting it in doh
cb400f2 x7
honda ss 50
gsx 1400
Offline Lynx
  • Repair & Despair Under One Roof
« Reply #4 on: August 05, 2014, 02:08:35 PM »
That hole goes to the oil pump.
Yamaha RD500LC
Triumph Speed Triple RS.
Previous bikes include
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
Offline steven400/4
« Reply #5 on: August 05, 2014, 07:57:19 PM »
its all sorted know
cb400f2 x7
honda ss 50
gsx 1400
