Author Topic: 1972 CB500 Four K1 cutting out  (Read 1257 times)
1stclassdiver
« on: July 23, 2014, 05:36:24 PM »
Hi, my bike has just started cutting out at any time, engine stops, no ignition, no lights, nothing. Poking about with the fuse, rectifier & the voltage control and it will come back to life but will cut out again at any time. Could this problem be to do with the rectifier or voltage controller?
Any info would be appreciated.
Re: 1972 CB500 Four K1 cutting out
« Reply #1 on: July 23, 2014, 06:19:23 PM »
No, either the fuse, fuse holder or ignition switch
1stclassdiver
« Reply #2 on: July 23, 2014, 07:24:11 PM »
Thanks for that, the fuse has been playing up a bit, is it worth upgrading to a blade type instead of the original glass type.
« Reply #3 on: July 24, 2014, 07:41:02 AM »
Simple answer YES
