Author Topic: Winter Work  (Read 17838 times)
Offline hondatri
Re: Winter Work
« Reply #45 on: November 27, 2014, 04:20:25 PM »
Hi again Guys enjoy the banter thanks for suggestion.
Offline hondatri
Re: Winter Work
« Reply #46 on: December 16, 2014, 04:38:59 PM »
Ok guys got the engine back together New piston Rings,Cylinders Honed Valves Ground in New cam chain and a Guide and Tensioner all new Gaskets and seals  I want to ensure valve timing is ok I have looked at Manual and not happy with it. The bike has Boyer electronic ign. Got pistons at TDC and with  the marks on Cam sprocket lined up the ign marks seem to be off a bit,Any Suggestions
Re: Winter Work
« Reply #47 on: December 16, 2014, 05:02:52 PM »
Sure i went through this with Drew. So here we go again: page 16 and 17 >>>   http://manuals.sohc4.net/CB350_CB400/CB400_CB350_SM_1.pdf
Steve, why do we not have a tech page or manual search?
Online SteveD CB500K0
Re: Winter Work
« Reply #48 on: December 16, 2014, 05:45:12 PM »
What did you have in mind?
2022 Tiger Sport 660
Re: Winter Work
« Reply #49 on: December 16, 2014, 05:45:20 PM »
They will be off, the "t" mark is for valve timing, the ignition timing marks are "f":))
Re: Winter Work
« Reply #50 on: December 16, 2014, 06:06:01 PM »
hondatri does ask: I want to ensure valve timing is ok I have looked at Manual and not happy with it. So it is the T mark at 1.4
Offline hondatri
Re: Winter Work
« Reply #51 on: December 16, 2014, 07:01:15 PM »
Thanks Trigger  that makes more sense than the Haynes Manual. Next Job is to strip and Clean Carbs I see a 4 carb Kit on Ebay has anyone used one of these.
Offline hondatri
Re: Winter Work
« Reply #52 on: December 18, 2014, 10:59:32 PM »
Hi its me againset up the valves ok On moving the bike stand I found what looks like a spacer Round 2.5" diawith a center hole of1.3" dia wit 2 holes kike for mounting, I cannot see anything similar in Parts Manual Is it off the 400/4
Offline Lynx
  • Repair & Despair Under One Roof
Re: Winter Work
« Reply #53 on: December 19, 2014, 07:05:01 AM »
Oh dear. That's supposed to go under the cam sprocket bolts .
Yamaha RD500LC
Triumph Speed Triple RS.
Previous bikes include
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
Offline hondatri
Re: Winter Work
« Reply #54 on: December 19, 2014, 11:01:46 AM »
I thoght as much I dont mind stripping top to fit it I know honda fitted it for a reason But would it matter if I left it off I mounted Cam sprocket and used Locktite on Bolts. I dont see that bit on my Parts  book.
Offline Lynx
Re: Winter Work
« Reply #55 on: December 19, 2014, 11:25:17 AM »
I'm sure as long as they are locktighted they'll be fine.
Yamaha RD500LC
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
Offline ka-ja
  • ken
  • yoshi 460
Re: Winter Work
« Reply #56 on: December 19, 2014, 08:10:05 PM »
Hi,
     My 400/4 did not have that piece fitted when I first stripped my motor in 1984, maybe different on some years/models? anyone any thought?
nice bike,nothing in the bank
Re: Winter Work
« Reply #57 on: December 19, 2014, 08:13:18 PM »
Hi,
Yep !
Re: Winter Work
« Reply #58 on: December 19, 2014, 08:40:24 PM »
The last one I restored DID NOT HAVE THAT.
So me personally would not worry about it providing the bolts do up to speck and have never loctited any off the cam bolts across the range
Bitsa
Offline hondatri
Re: Winter Work
« Reply #59 on: December 20, 2014, 09:02:23 AM »
Thanks for all replies. I have decided to leave well enough alone and hang that bit on garage wall. So its on to Valve adjustments
