Author Topic: Front fork problem  (Read 3711 times)
Offline Greg65
Front fork problem
« on: October 22, 2014, 11:04:59 PM »
I am replacing the seals on the front forks. The first one has come apart fine however ( there is always a however) the second is sulking. The bottom socket bolt, oil lock piece and under seat pipe are all rotating! So how do I hold the internal gubbins still while I undo the socket bolt. Thanks in advance for your wise words.
Greg
Keep smiling it makes the management nervous.
Honda CB400 1976
Suzuki GS1000 1978
Re: Front fork problem
« Reply #1 on: October 23, 2014, 08:46:09 AM »
Put the fork back together with spring and top nut the hold fork upside down and push down on slider to compress spring
Offline Clem2112
  • Midlife
« Reply #2 on: October 23, 2014, 09:08:32 AM »
Second that... you need friction to hold the inner damper rod still.
Offline steven400/4
« Reply #3 on: October 23, 2014, 09:25:46 AM »
or use the speed of an air gun that worked on mine
cb400f2 x7
honda ss 50
gsx 1400
Offline matthewmosse
« Reply #4 on: October 23, 2014, 11:20:40 AM »
Sharpen a broom handle like a pensil and bang it in with a hammer can work too.
Offline MikeM
« Reply #5 on: October 23, 2014, 11:59:50 AM »
the way I got mine off was wrap fork in a towel put it in a workmate or the like and use an allen key on a socket,
one like this
http://www.ebay.co.uk/itm/Signet-6mm-Allan-key-socket-3-8-drive-/251681322950?pt=LH_DefaultDomain_3&hash=item3a996037c6
did not use a lot of pressure , more of a snap action to break the seal
Offline Greg65
« Reply #6 on: October 23, 2014, 04:45:29 PM »
Thanks for all the advice. First up tried the reassembly and spring compression method, no joy. So picked up the offending fork and walked down the road to my local garage. Air gun worked a treat. If I had known would have gone there with both in the first place.
Now a quick question for the assembly. The workshop manual mentions a " liquid sealant" on the threads of the socket bolt prior to assembling. Any particular type?
Cheers,
Greg
Honda CB400 1976
Suzuki GS1000 1978
Offline Lynx
  • Repair & Despair Under One Roof
« Reply #7 on: October 23, 2014, 05:34:49 PM »
Hi Greg,
I'm surprised they say use a sealant. I never have. there should be a copper washer under each Allen bolt. This should seal fine. You could use some of the dreaded silicone gasket but just a smear. I wouldn't use locktight and you will have trouble getting them apart again should you or anyone else ever need to.
Yamaha RD500LC
Triumph Speed Triple RS.
Previous bikes include
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
« Reply #8 on: October 23, 2014, 05:55:50 PM »
I have seen threadlock mentioned in the cycleserve manual, presumably to prevent the bolt working loose in service, think about it, if the bolt came loose, what is holding your fork leg together, frankly, nothing. I bought a pair of n.o.s. fork legs from D.S.S. About 20 odd years ago, and one of the seals leaked, so took them apart to renew them, and there was some kind of sealant/thread locking compound on the factiry fitted bolts. So I used some loctite thread lock on rebuilding, and had no problems dismantling them to do the seals again 10 years ago. It's up to you, but I would certainly go for a thread locking compound.:))
Sent from my GT-S5839i using Tapatalk 2
Offline Greg65
« Reply #9 on: October 24, 2014, 08:18:29 AM »
There was some sort of sealant/thread lock present around the lock bolt when I dismantled them. I have heat treated the copper washers so will see how that goes.
Honda CB400 1976
Suzuki GS1000 1978
« Reply #10 on: October 24, 2014, 09:24:33 AM »
Your bike, your choice, but if Honda specify sealant/locking compound, they do it for a reason!???
« Reply #11 on: October 24, 2014, 09:29:24 AM »
Done loads, never ever used threadlock but sometimes new washers
« Reply #12 on: October 24, 2014, 09:33:49 AM »
Same as Bryan, done shed loads over the years. Seen them with & without thread lock but, always build without.
Offline Lynx
« Reply #13 on: October 24, 2014, 11:08:17 AM »
However. Always torque to specified torque.
Yamaha RD500LC
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
Offline Greg65
« Reply #14 on: October 24, 2014, 11:14:25 AM »
As the forks are penciled in for a rechrome and grind in the near future I will leave it out. Many thanks for all the wise words.
Greg
Honda CB400 1976
Suzuki GS1000 1978
