Author Topic: Re-build stalled pending your help...  (Read 968 times)
Offline Drew400
  • 400/4 I restored
« on: October 25, 2014, 10:11:36 AM »
Hello all,
I'm about to fit the cylinder head and find myself temporarily stymied!
At the base of each cylinder is a large o-ring (c.55mm diameter) - part no. 91301-377-000. The ones I removed during the dismantling stage appear to be semi-hard 'plastic' with a break in them, rather than being proper o-rings. Two of them were brittle enough to snap when being removed. See photo below.
My questions are: 1) are they designed to be as described above and therefore a very specialised part that I need to order or should these be basic and continuous o-rings? and 2) there are 4 rubber o-rings of c.55mm diameter in the gasket set I bought from David Silver. Are these to be used at the base of the cylinders (I can't yet think what else such large o-rings would be used for)?
Thank you. I may be able to complete my planned weekend work with your help rather than putting it off for yet another weekend whilst I await parts I didn't realise I needed!
Cheers, D.
Offline ka-ja
  • ken
  • yoshi 460
Re: Re-build stalled pending your help...
« Reply #1 on: October 25, 2014, 11:11:11 AM »
Hi,
     They start off life as "o" rings, so re-fit with the ones from your kit, pushing well into the groove at the bottom of each liner.
nice bike,nothing in the bank
Offline Drew400
  • 400/4 I restored
« Reply #2 on: October 25, 2014, 11:28:09 AM »
Rather hoped that was the answer!
Cheers,
D.
