Author Topic: New steering bearings  (Read 1400 times)
Offline rockvegas400
« on: October 30, 2014, 12:05:50 AM »
I am fitting a set of tapered steering head bearings form David Silvers, which came with a washer that goes on the stem below the bearing cone. Should I also install the thin Honda washer and dust seal?
Justin
'75 CB400F
'88 VFR750F
Offline Clem2112
  • Midlife
Re: New steering bearings
« Reply #1 on: October 30, 2014, 04:30:55 PM »
From memory,  I think I left something out when using their taper headset - couldn't get the thick spacer on ?
Offline Lynx
  • Repair & Despair Under One Roof
« Reply #2 on: November 04, 2014, 06:50:56 PM »
Hi Justin,
You do need the spacer and seal under the bottom race.
Steve.
Yamaha RD500LC
Triumph Speed Triple RS.
Previous bikes include
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
« Reply #3 on: November 04, 2014, 10:17:20 PM »
Thanks Steve,
I worked on the assumption that these items should be used.
My latest problem is that it appears that I have stripped the thread on the adjuster nut, as my bearings will not tighten up enough to be rideable. Will have to pull everything apart again to inspect. Perhaps the 6mm or so of upper bearing seat that protrudes from the steering neck in the new set-up has contributed to this issue. I had to find a thinner lock-nut washer  to enable it to get purchase on the upper thread also.
Has any one had their steering stem re-threaded?
Justin
'75 CB400F
'88 VFR750F
Offline Lynx
« Reply #4 on: November 04, 2014, 10:24:40 PM »
Did your bearing set come with 2 spacers of different thickness? If so, use the thinner one under the bottom race. Obviously the thicker this spacer is the less stem will be sticking up through the top yoke.
Yamaha RD500LC
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
« Reply #5 on: November 05, 2014, 01:16:48 AM »
The DSS kit came with one spacer only.
'75 CB400F
'88 VFR750F
