Author Topic: CB750F1 Project  (Read 21022 times)
Offline mick
Re: CB750F1 Project
« Reply #15 on: November 14, 2014, 09:31:36 PM »
it looks like grease out of a grease gun , think the engines fit for a boat anchor  ;) cheers mick.
Offline LesterPiglet
  • 1977 CB550F2
Re: CB750F1 Project
« Reply #16 on: November 14, 2014, 09:41:20 PM »
That head damage wasn't caused by rings as it extends beyond the bore. My guess is it was caused by a twat.
Offline martin_uk
Re: CB750F1 Project
« Reply #17 on: November 14, 2014, 11:06:43 PM »
Just the effect of water in combustion chamber over an extended period of time.
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Offline martin_uk
Re: CB750F1 Project
« Reply #18 on: November 14, 2014, 11:08:08 PM »
2014_0425cb750B40025 by nitram2010, on Flickr
What in the hell is that thing?  Is that a worm?  You must have very different worms on your side of the pond.
I think that someone thought that squirting grease in there would help to un seize ::)
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Offline matthewmosse
Re: CB750F1 Project
« Reply #19 on: November 15, 2014, 07:59:48 AM »
on mine, the rings had smashed their way out of the top of the piston somehow and gotten trapped between the piston and head causing similar dammage, then someone had poped the head off, removed the debris. I went one further and replaced the pisteons but ran a head with very similar dammage. Water doesn't do that to a head, I had an engine where all the cultch casing had literally corroded away, gearbox totally shot, somehow the head was immaculate once a few kilos of thick clay mud were removed from inside the rocker cover. I still think it sensible to source a replacement engine though I have thashed a few years commuting out of 550s with parts that rough.
Offline UK Pete
Re: CB750F1 Project
« Reply #20 on: November 15, 2014, 12:49:36 PM »
Ok martin here are the pictures as promised , the engine seems to be complete, but is totally stripped, this is how i bought it, it was stripped as it needs reconditioning, probably rebore and the usual things like cam chain and tensioners etc
Some of the outer covers are no good , the altenator cover has damage, and the sump plug hole has been welded up
The F1 exhaust is about as good as you will find for a second hand one, very solid , the side that you see is still quite bright but far from perfect, the rear where it does not get cleaned has fine surface corrosion but solid no holes , tiny crack where it clamps up, but very usable
Here is the link to the pictures the price is £300 for the lot
http://s924.photobucket.com/user/UK-Pete/library/392%20engine%20and%20%20F1%20exhaust
Offline martin_uk
Re: CB750F1 Project
« Reply #21 on: November 15, 2014, 02:42:35 PM »
Thanks Pete, really appreciate your help.
I can collect today if you are available, will call to arrange.
Can I make a final decision on silencer when I see.
Thanks again.
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Offline martin_uk
Re: CB750F1 Project
« Reply #22 on: November 16, 2014, 04:42:59 PM »
Thanks to Pete, now have another engine to play with :D
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Offline martin_uk
Re: CB750F1 Project
« Reply #23 on: November 16, 2014, 04:47:32 PM »
Here is the bike as I received it.
2014_0418cb750B40003 by nitram2010, on Flickr
Doesnt look too bad, but I wanted to get rid of all the rust, so completely stripped
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Offline martin_uk
Re: CB750F1 Project
« Reply #24 on: November 16, 2014, 04:50:08 PM »
Carbs are pretty grungy
2014_0420cb750B40005 by nitram2010, on Flickr
2014_0420cb750B40001 by nitram2010, on Flickr
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Offline martin_uk
Re: CB750F1 Project
« Reply #25 on: November 16, 2014, 04:55:50 PM »
I wont have to use this engine after all :o
2014_0404BM0012 by nitram2010, on Flickr
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Re: CB750F1 Project
« Reply #26 on: November 16, 2014, 04:59:53 PM »
Not a bad looking bike. Those carbs will clean up.
Have a rear brake peddle for one of those on fleabay.
« Last Edit: November 16, 2014, 05:02:52 PM by Trigger »
Re: CB750F1 Project
« Reply #27 on: November 16, 2014, 05:51:28 PM »
Keep it yellow. I do like that colour on the F1.
2022 Tiger Sport 660
Re: CB750F1 Project
« Reply #28 on: November 16, 2014, 06:37:26 PM »
I am with you on this one Steve. Yellow is the best colour on the F1.
Offline UK Pete
Re: CB750F1 Project
« Reply #29 on: November 16, 2014, 06:44:27 PM »
Great to meet you martin , hope the bits are useful , btw looks like trigger also has the rear master cylinder your after on ebay
Oh yes yellow is really nice on the f1, does anyone know if the f1 is Sulpher Yellow, or parakeet yellow?
pete
